跳转到主内容
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75 个问题 查看全部
My galaxy s5 active will only turn on with USB cord plugged into wall
my galaxy s5 active will only turn on with USB cord plugged into wall and i have to push the cord a certain way in the charging port. i have tried different batteries but it wont turn on unless its plugged in. then once it finally fires up it will stay on less than a minute than shut off. IN MADNESS I DWELL !!!!! PLEASE HELP
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Clean the charge port out as carefully as possible so as not to damage any pins. They usually end up full of lint and other crap from our pockets. If that has already been done then replace the charge port.
Follow this guide to replace the charge daughter board.
Galaxy S5 USB Daughter Board Replacement.
The new replacement part is available from here.
Galaxy S5 Charging Assembly.
The hint to me is this " i have to push the cord a certain way in the charging port.".
Galaxy S5 (T-Mobile) Charging Assembly图片
产品
$29.99
这个答案有帮助吗?
得分 0
2条评论:
Make sure you get the correct revision of the charging port daughterboard. There are at least four variants about. Use the wrong one and you won't be able to charge or use 3/4G.
完成的
Also 30 dollars is ridiculously expensive
完成的
添加一条评论
You have tried several batteries. That they don't work shouldn't be dependent on the charging port connector. Have you tried using an external charger to charge one of these batteries up? It might not be worth replacing the charging port if you can get by with an external charger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 251
