跳转到主内容
加入维修社区 - 创建账户
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
Stiff Touch ID button
Hi
My touch id button feels like there is something stuck underneath it, or on the sides. As in, when I try to press it, I hear a sound like something gives way, and it takes a hard press to do so. Subsequent presses at the same time feel almost normal (soft squishy feel). Even if I get back to it after a minute, its stiff the first time, and almost normal if I want to press it three times in a row.
Any ideas whether the Touch ID button is removable, and clean underneath?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you finally got it fixed or did you had any further limitations or damage after. Thanks for sharing your experience.
完成的
添加一条评论
2个答案
最有帮助的答案
If you still have warranty coverage or enrolled in AppleCare + then I would recommend you let Apple fix this as it should be covered under warranty.
Its a bit of work to get to the back side of the uppercase where the touch ID is attached. If you damage it you'll kill your system! As its linked to the logic board.
这个答案有帮助吗?
得分 3
添加一条评论
I had the same situation with my MacBook Air. I fixed it by using an air compressor to shoot air under the button and clear any debris. Failing that, you should use warranty/AppleCare if possible
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shyam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 53
总计 2,002
