跳转到主内容
加入维修社区 - 创建账户
ASUS_D550MA-DS01 是华硕在 2013 年发布的一款笔记本电脑。
ASUS Laptop boot problems
I have an asus laptop. I got windows 8.1 on it. One day, when i tried to turn it on, it said preparing automatic repair, followed by a black screen(but it was still on). I left it on for 2 days, and decided to manually shut it down. The problem persisted. One day, after many tries, i got access to it. Then i tried setting up windows 7, in hope that it was just a problem with windows 8.1. It wasn't. When windows 7 was installing, it needed to restart. When it did, it took me to a screen with the boot manager, now having two options. Windows setup, and windows 8.1. When it went to that screen, I let it automatically go on windows setup, which was highlighted. It froze at the screen where it said starting windows with the logo. After waiting a while, i manually shut it down. Now, i couldnt access anythingn except the "aptio setup utility" when i press f2 on boot. Ive tried booting it with a flash drive(i have no discs) that had windows 8.1 setup. It didnt boot it. I also tried with windows 7 and same outcome. I was able to boot a linux mint cinnamon. It didnt work for any other os i tried. When i tried to boot with windows 8.1, 7, and linux i burned the iso to the flashdrive. If anyone knows the problem, please tell me. I have been trying to solve this for over a month
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
White screen , aption utility
由完成的 分享
添加一条评论
7个答案
最有帮助的答案
This sounds like it might have some bad sectors on the HDD. In BIOS you should be able to have it run a check on the health of the HDD.
这个答案有帮助吗?
得分 1
1条评论:
how do i do the check of health?
由完成的 分享
添加一条评论
Hi , We need to first fix the Boot Record then check and fix hard drive errors.
1.Make sure you can boot to your Windows 7 installation usb drive.
You have to go in bios to security option then disable USB security so it will be able to boot to USB drive, then go to boot options and add New boot option that will be the USB, then make it boot option 1.
2. Restart the computer with the optical disk or USB drive inserted and boot to it. Press any key when prompted to boot to the Windows USB.
3. At the language and keyboard selection screen press Shift+F10 to open a Command Prompt. You should see X=Sources>, now type bootrec /fixmbr, it will say completed successfully. Stay at the command prompt, now on to the check disk
4. What is usually the system C drive may not be here because if there is a system reserved partition it will occupy C instead. To find out type Dir C: and if it says “C is System Reserved” try Dir D: and so on until you find the drive with Program Files, Users and Windows folders.
5. Now you know the assigned letter for the system drive you can run Check Disk
At command prompt X=Sources> type the letter of drive you found in previous step, example X=Sources>d:
You should see this now D:\> type chkdsk d: /f
You should see this D:\>chkdsk d: /f then hit enter to fix hard drive
If it says do you want to force dismount answer YES
If all goes well you should now be able to do a clean windows install
Have a great day
这个答案有帮助吗?
得分 0
6条评论:
OK, so I have the windows 7 installation on my flash drive. I can't boot with it though. Maybe its because I'm dual booting? I tried turning off fast boot in the BIOS, but it wont show up as an option for booting, and wont boot automatically.
由完成的 分享
由完成的 分享
i dont see any usb security under the security tab, is it the secure boot control?
由完成的 分享
That is probably it, secure boot control, you should be able to disable it, may be a little different than how I explained it, just as long as you can boot to USB drive.
由完成的 分享
it didnt let me boot it, even though i turned off secure boot control, i looked up alot of things and none worked, i believe it worked when i was getting linux mint so idk
由完成的 分享
显示更多的1条评论
添加一条评论
I got this from Eassus.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Of course, some data may be gone, and you may come across some problems but you can read the entire article here: https://www.easeus.com/resource/fix-prep...
这个答案有帮助吗?
得分 0
1条评论:
this doesnt work, maybe because im dual booting?
由完成的 分享
添加一条评论
Hi
Just go to bios and make csm enable
After that save and try
这个答案有帮助吗?
得分 0
添加一条评论
App Navigator | Drag and drop to rearrange and manage your app windows across display
这个答案有帮助吗?
得分 0
添加一条评论
Keyboard macet
这个答案有帮助吗?
得分 0
添加一条评论
Remember to back up your important data before proceeding with any troubleshooting steps.
Check Hardware:
RAM: Try removing and reseating the RAM sticks. Test each stick individually if you have multiple.
Hard Drive: Run diagnostic tests on the hard drive to check for errors. You can use tools provided by the hard drive manufacturer or use third-party diagnostic software.
Other Components: If possible, test with different components like the power supply or display to isolate the issue.
Re-create Bootable Media:
Ensure you're using a reliable method to create bootable media. Use tools like Rufus or the Media Creation Tool provided by Microsoft.
Verify the integrity of the ISO files you're using.
Access BIOS/UEFI:
Check the boot order in the BIOS/UEFI to ensure the bootable media is listed first.
Disable any security features like Secure Boot that might interfere with booting from USB.
Attempt Windows Recovery:
If you can access Windows Recovery Environment (WinRE), try using the Startup Repair or System Restore options.
You might need to create a Windows installation media to access WinRE.
Clean Install:
If all else fails, consider a clean installation of Windows. This will erase all data, so back up important files beforehand.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rokpoko 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 38
总计 7,449
