跳转到主内容
加入维修社区 - 创建账户
1997-2006 年生产的 TJ 系列牧马人(Wrangler)。
How to repair reverse switch on automatic 2001 Jeep TJ
My reverse lights dont works on my Jeep trying to replace the switch but I can't locate it for an Automatic transmission, All guides I've found are for Manual transmission. Any help will be welcome
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If you have the 4sp auto 42RLE then the only switch I can find relevant is the Transmission Range Switch.43RLE Bottom left picture switch number 3. Again called a TRS. The other two are input and output switches.
If however it is the 3 speed auto either the 30/32RH unit then it is a 3 pin neutral/safety switch. location
That might look something like this, 3 pin
Edit:
Based on that location picture, I think we are looking at an upside down view of the tranny. As that looks a lot like the edge where the pan sits. So I'm going to say left hand side, lower.
这个答案有帮助吗?
得分 1
1条评论:
I believe mine is the 3-speed so where of you start to look is the location from that diagram?
完成的
添加一条评论
添加你的答案
John Dooley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 3,054
