跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
Turn iPad off when testing without touchscreen
Hi,
Just replaced de iPad battery, and placed back the logic board and LCD. After that I wanted to test the LCD, and this worked out fine. But now I need to turn the iPad off again, to place the screen.
How do I turn the iPad off without a touch screen and home button?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Lift up the connection from the battery.
To do this you will need to lift up the logic board until it stops touching the battery connector with the battery.
The logic board is pretty much stuck down by adhesive so you can keep lifting up the logic board near battery connector with your fingernails and loosen it.
Once it stops contacting with the battery, the iPad will be off, put something like a guitar pick to stop it from connecting again.
这个答案有帮助吗?
得分 3
2条评论:
Thanks, are there no risks for shocks or something?
完成的
No risk. Metal prying tools are not being used to do this.
完成的
添加一条评论
添加你的答案
Michel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 86
