跳转到主内容
加入维修社区 - 创建账户
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
iMac won't turn on
Hello.
I inherited an iMac (27-in mid-2011) this year. The previous owner had removed all their files and reinstalled all the latest iOS etc.
We were able to get it started after I picked it up over a month ago. I had left it on and plugged in for a couple of weeks and then last weekend I realized it had gone 100% dark. It has been like that ever since. Have tried different outlets. Tried plugging and unplugging back of machine. Tried removing accessories (just keyboard). I replaced the old power cord with brand new one, but still no life.
I'm a newbie in DIY repairs but I guess I'd like opinions on whether to return to Apple Store for scrap, or if it is worth troubleshooting via some IFIXIT solution (and if so what would you try first?). Thanks for any input!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If you can carefully remove the display iMac(英特尔27寸EMC 2429版本)显示器更换指南 you should be able to see the onboard diagnostic LED's Which are just below and to the right of the HD on the main logic board
Do any of the LED's light up? If not and your sure the power cord is good and plugged into a good outlet then the power supply needs replacing. Here's the guide you'll ned to follow to take it out: iMac Intel 27" EMC 2429 Power Supply Replacement and here's the needed part: iMac Intel 27" EMC 2309, 2374, 2390 or 2429 Power Supply.
The tricky part is not damaging the display cables when you take the display off.
Replace a broken or damaged power supply compatible with an iMac 27" Intel (Late 2009 to Mid 2011).图片
产品
$149.99
iMac Intel 27" EMC 2429 显示器图片
指南
难度:
中等
15 minutes
iMac Intel 27" EMC 2429 Power Supply图片
指南
难度:
中等
20 - 30 minutes
这个答案有帮助吗?
得分 3
4条评论:
Nice! - Thanks, Dan & Eigirdas! I will take a look at that guide + replacement! If I do replace the power, and it powers on again - Assuming hypothetically it is then in decent running order, how many years do you think potentially it may have left in it? Is that something anyone can estimate? One or two years at least? Or are there other components that typically die?
完成的
Mine is still kicking ;-} And I'm hoping to get at least 3 more years if not more! I've upgrade it with 16 GB or RAM & a second drive (500 GB SSD) it really sings!
完成的
That's awesome!! I'll let you know how it goes. Thanks again!
完成的
Hi again! I am VERY happy to report back that I replaced the power supply this Saturday, with all of your suggestions above, and the iMac turned on perfectly. Thank you again, so much!
完成的
添加一条评论
Just to clarify.... when you pressing power button, it makes no noise, sounds ?
这个答案有帮助吗?
得分 1
2条评论:
Hi! Yes, that is correct - there is no sound. No indication of life. I have been on the phone twice with Apple Support, to attempt to turn it on. They no longer support this machine so will not be able to even try to repair. They were going to set up an appt for me to drop it off but I thought I would see if there was any ifixit option before I do that.
完成的
Follow Dan then, because hes comment was identical to mine:D
完成的
添加一条评论
添加你的答案
Amy C 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 56
总计 8,462
