跳转到主内容
The Sennheiser RS 120 is an RF wireless headphone system with open, supra-aural headphones.
52 个问题 查看全部
Getting into the Sennheiser RS-120 Charging cradle
How do you take the front plate off a Sennheiser RS-120 charging cradle? The covering on the RCA male jack wire to the cradle has decomposed and needs replacement. Easy to do if you can get inside the box. Doing so is the puzzlement.>
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First remove the two small screws that are visible on the back panel. Then **carefully** pry apart the front grey panel from the black rear panel. The plastic is designed to clip together very tightly. Use a credit card or blunt knife. The bottom should come free first, as the top hooks into place. There are no other screws.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Donald CE Ferguson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 60
