跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
My iPhone 4s screen is glithcing anf flikering but cant see the screen
so at scool i droped my iphone 4s on the screen didnt crack and no visible damage but the screen was white with lines and it was flickering and i couldnt seee the screen. but the touch response worked so i was able to do my pasword but couldnt see a thing. i was able to see that it worked cause the lines moved when i touched something. any idea or fix that i could do that doesnt involve me replacing the screen because i dont know how and it is very complicated.https://youtu.be/5rJW74Mrqq4
this link is a video that shows my iphone yet i didnt show that it responded to touch.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I can't be certain, but it does sound like the screen could have sustained some sort of damage and would need to be replaced.
完成的
添加一条评论
2个答案
已选择的解决方案
If you're lucky you may be able to fix it by reseating the display connector. Changing the screen is quite difficult on the 4S if you haven't done this sort of thing before because the ribbons pass through a narrow slot and are very easy to tear as you try to feed them through - I know - I've done it!
You will need a set of precision screwdrivers. Always press hard to loosen screws so as not to damage the heads - quite easily done. (See https://therestartproject.org/wiki/How_t...)
Follow the guide for rear camera replacement at 更换iPhone 4S后置摄像头
You'll need to disconnect the battery but you needn't remove it - it's stuck quite firmly with glue.
Having removed the cable cover plate in step 10, the display data cable is the one to reseat. This is shown in iPhone 4S 屏幕更换 step 17. Having lifted it off it needs to be precisely aligned to get it back on. This will take a little patience, but don't worry, it will go back! Don't try to force it or you might damage it. You will feel a positive click when it engages. Make sure both ends are engaged. Make sure the other connectors haven't been dislodged.
If this doesn't fix it then I'm afraid it's going to be a new screen.
iPhone 4S 后置摄像头图片
指南
更换iPhone 4S后置摄像头
难度:
中等
30 minutes - 2 hours
iPhone 4S 屏幕图片
指南
iPhone 4S 屏幕更换
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 2
添加一条评论
I would say it is one of these problems:
1.) The rippon cable for the screen is loose or damaged
2.) The LCD is damaged
Most likely the ribbon cable as if the LCD was broken it would have a blotchy ink look, but I could be wrong. If opening it and examing the cable/reseating it doesn't help then you'll need a new LCD.
To be honest with you if you highly doubtful yourself with the repair the iPhone 4 is pretty cheap to get fixed at most places. I don't want you to break your phone (more).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 83
