跳转到主内容
A mid-size Jeep SUV, sold from 2006 to 2010. Produced in both XK (gas) and XH (diesel) variants.
5 个问题 查看全部
Why is my sun roof leaking?
Sun roof leaking un-attached cable binding window when in operation please help. electric cable on one side of the sun roof detached
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you use the manual winder to completely close the sunroof?
完成的
添加一条评论
1个答案
最有帮助的答案
I have a 2006 Jeep Commander purchased in 2010 from a dealer. Great car at first. However, among other things, my sunroof leaked into the side beams ("A" Posts) which resulted in inches of water on rugs...both sides...passenger & driver! After many frustrating attempts to get corrected, I finally tackled the issue.
Result: When the sunroof is open, there are four (4) drain holes at the four 'curved corners' which allow (supposed to...) water to drain down via hoses. Front two hoses exit and drain behind front tires and rear hoses drain between front & rear doors. I found the drain holes/hoses were easily 'plugged' by road debris or tree/leaf debris. Solution: Using a stiff but flexible length of weed wacker string (e.g., 0.95 dia.) and a small amount of HOT water, I was able to dislodge the blockage and get the drains/hoses to function. Usually it's the front drains that plug. Good luck.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Kitty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 26
总计 428
