跳转到主内容
A collection of guides and support to help with washer repair.
3482 个问题 查看全部
LG front loader won't drain
I have an LG front loader that won't drain. I can hear it buzzing like the drain motor is trying to drain, then I get an "OE" error ("no drain" issue), and it stops without spinning.
So, I removed wet clothes, drained the washer manually and checked the drain filter/trap (it was clear). I then turned on the drain/spin cycle with an empty load and it worked (started spinning).
I put the very wet (soaking) clothes back in, started the drain/spin cycle and I hear the drain motor trying to drain and then get the OE error again and no spinning.
I tried a master reset as described in LG WASHER won't drain or spin. No joy.
Any suggestions on what to try next. Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
So, I called in the professionals - he said it was a problem with the pump impeller. Cost to fix is $311.
这个答案有帮助吗?
得分 0
3条评论:
What is the reason our clothes sour after washing in cold water
完成的
Do I need a trap on my drain
完成的
The water sits in the pump and sleeps through into the impellers trapping stagnant water so I would say you need a new pump
完成的
添加一条评论
pump out of my washer
这个答案有帮助吗?
得分 0
添加一条评论
pump out of washer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bocotim 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 34
总计 14,908
