Jog dial control buttons on Olympus OM-D E-M1 twitchy or sticky
I have the above camera which works well, but when I need to access the menus via the "jog dial" / buttons, they either stick and need extra pressure to regiter a push, or are super-sensitive and react too fast (like a double-click...) .
I suspect that the buttons are slightly loose or mis-aligned behind the case. I'd like to open the back of the housing to verify / repair / tighten / clean the buttons.
Does anyone have info about the procedure to remove the case / housing ?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
