跳转到主内容
The Asus X551CA is a 396.2 mm laptop computer with convenient features for everyday use.
Why can't I see the SSD connected via USB port under "My Computer"
Hi all,
I decided to upgrade my Asus X550CA laptop with a Crucial SSD. I wanted to clone my existing hard drive however when I connected the SSD to my laptop via USB connector, I could not find it under My Computer.
I have tried to find am answer with no luck. When I go in disk management I can see the new SSD there in the bottom half. At the top half i see only C: and D: drives. Also, the driver for the new SSD is installed because I can see the SSD in Device Manager and I can elect it to unplug. So it seems that windows is not assigning it a drive letter. I have windows 8.1.
Has anyone one had a similar issue?
Thanks in advance,
GA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
I am using EaseUS.
完成的
By the way, it is the free version of EaseUS. By initializing the disk do you mean I have to partition it?
Thanks
完成的
What if it states “NO Media” for the drive under Disk Management? I have already assigned a letter for the drive.
完成的
Hi @Elisha Satterfield
I suggest you start a new questions with more details to be noticed.
完成的
添加一条评论
3个答案
已选择的解决方案
Actually I got it to work after watching a you tube video. In case someone runs in similar issue, the SSD needs to be initialized. I went in Disk Management, where my SSD showed as unallocated. Right click on it and choose New Volume. Then in the window that pop up check assign letter drive, format and that's it. Worked for me.
这个答案有帮助吗?
得分 13
6条评论:
This worked. Make sure you assign the drive letter or it still won't see it.
完成的
Thank you ^^ thought my cheap amazon cable was defective!!! <3
完成的
Thanks so much!
完成的
This worked with my new SSD Samasung EVO 870. This simple short suggestion was all that I needed after seaeching dozens of quasi complex suggestions on Google. Thank you author
完成的
same as above new evo 870, ty so much!
完成的
显示更多的1条评论
添加一条评论
Hi genti agastra , i suppose it is a new SSD, yes, if you see in disk management on the SSD device, means your SSD is detected on the computer.
The reason you are not seeing the Drive letter, is most probably, the disk is not initialized yet.
what software do you use for cloning?
most cloning software should be "smart" enough if you start the cloning, it will see this new SSD drive as the destination
这个答案有帮助吗?
得分 2
添加一条评论
Do you use the correct usb Cable?
Sometimes you need a two port Power usb to get the correct Power to the hdd.
这个答案有帮助吗?
得分 1
1条评论:
I have tried two types of USB to SATA connectors. I am pretty sure that is not the problem
完成的
添加一条评论
添加你的答案
genti agastra 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 60
过去 30 天: 277
总计 49,201
