跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone 7 Plus in bootloop and unresponsive after restore!
My phone is pretty much all around malfunctioning and I need help.
The first time problems arised was when I received a call and I could not hear anything and the microphone was not picking up my voice, so I tried resetting but that only caused my phone to enter a bootloop. I’ve dealt with this before so I tried entering DFU mode, letting the battery completely die, restart restart restart, but nothing. Wasn’t until I tried restoring where I realized something must be really wrong with the phone, tried restoring and it would just enter bootloop and never end. However sometimes the phone would actually start up if I updated the carrier settings before the restoring process finished. But even then the phone was acting super weird, the little pop ups asking you simple things like to cancel or allow location would cause the entire phone to become unresponsive, only way to get it back would be to press sleep button. After passing setup screen I started to check around the phone, both cameras did not work, speaker did not work, trying to toggle something in settings would freeze the phone , certain apps would not load up, App Store opened but never loaded anything. Safari did partially work but if I tried scrolling down on some pages it would just freeze again. I can send messages but that’s about it, WiFi and Bluetooth seem to be working as well. If the phone for whatever reason is turned off or has to restart then it will return into the bootloop unless I try to restore it to get it to work. There also haven’t been any screen replacements on the phone I am pretty sure, it just happened randomly about a week ago.
Does anyone have any advice on what might be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
已选择的解决方案
Chances are the audio chip on the board needs to be replaced.
Requires board level repair / someone that does microsoldering from a reputable repair shop to get the chip replaced
Audio chip commonly caused Apple logo boot loop and the other audio issues you have specified above.
Reputable shops are the one that offer a no fix no fee model.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Giovanni Jimenez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,663
