跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Using external PSU for additional Harddrives
Hi there,
I have got a Mac Pro 2006 2ghz (Basic model). It is not my every day Machine, it is more likely my toy. I found out today that it has in addition to the four HDD enclousures two sata ports on the motherboard. I connected to them two sata cables. Since I do not have any powerconnectors left over, my idea was to use a second PSU to power the drives which I want to connect to these extra SATA ports. So my question, will it harm my computer/Mac if I will power a Harddrive from another PSU than the Mothermoard is powered and connect the sata data cable to the motherboard?
So it would like this:
1. PSU of Mac pro Powers mother board
2. External PSU power's two HDD's
3. Connect the two HDD's to the motherboard (Sata-Data Cable only)
Greets Simon
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you clarify your current setup.
The four HD bays which you access from within the system have both data & power.
The upper bays are for optical drives and you should have two connections already there to hookup two full sized optical drives.
完成的
There are near the two six pin connector for the GPU two SATA ports, google "hidden SATA ports mac pro 1.1". So I have two optical drives, 4 HDD in the HDD carriers, and these two SATA ports. I d'like to use these two ports additionally to the rest (there is not any power connector left over) . Can I power the these two HDD's with another Power Supply and then connect the Data-SATA cable to the ports on the motherboard?
完成的
添加一条评论
2个答案
已选择的解决方案
I would recommend you just bring the SATA connections to a spare PCI slot and mount up a eSATA port board like this NewerTech eSATA Extender Cable Adapter Then just plug in an external eSATA drive case like SB 3.0/eSATA Dual 3.5” SATA III Hard Drive External RAID Enclosure w/power supply & fan
That way you have a neater setup and you don't need to worry about the power supply and you can then double up the your 2 SATA ports into 4!
这个答案有帮助吗?
得分 2
添加一条评论
The external PSU shouldn't harm your system. However, you'll need to have a way to turn on the external PSU. Usually a paperclip between the green and black connection to power it on.
这个答案有帮助吗?
得分 0
1条评论:
You do need to be careful when adding power internally as the AC outlet wiring can cause a cross-wired condition if one is not careful which will blowup your system. You also need to consider the added heat as well.
Best to run the SATA connections to an external case (eSATA) which has its own power supply and cooling.
完成的
添加一条评论
添加你的答案
Siki 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 876
