跳转到主内容
加入维修社区 - 创建账户
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why isn't the flip cover settings working anymore?
I don't see the clock anymore in flip cover window after pressing power button. I see the home screen. Also when I open the flip cover screen stays black for so long I tap the screen to get to my home screen. This was working perfectly weeks ago. Settings haven't been touched and flip cover settings is on. Phone is so much slower over all even after boosting. Deleted many apps still way slower. Was great initially but not the same now. Using Evie.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
After restarting my phone and disabling some apps it started. Working again.
完成的
Maybe post that as an answer so this shows up as solved? That way, others with the same problem will find this post.
完成的
添加一条评论
2个答案
已选择的解决方案
这个答案有帮助吗?
得分 0
添加一条评论
Hey Jody,
It sounds like you may have a broken (or blocked) IR proximity sensor. I believe the sensor comes with the display assembly, so it may be as simple as replacing the screen, but I/you will need to check. If it is, check out this guide.
Hope this helps,
-Tanner
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jody 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 433
