跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
Best bluetooth antenna for BCM94331PCIEBT4CAX
Goodmorning everyone,
someone would advise me which of the following two bluetooth antennas is best to use with the wifi / bluetooth (4.0) module BCM94331PCIEBT4CAX for a "MacBook Pro 17 Late 2011"?
1. K17 056-3518-A
2. 631-1570-10
I ask which of the two antennas will be able to offer greater coverage and stability of the bluetooth signal.
Thanks for the assistance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Neither of these are the correct part.
完成的
添加一条评论
2个答案
已选择的解决方案
This is the correct part Unibody MacBook Pro 17 Airport Antenna (2011) - Apple P/N 631-0890-B. There is no options here.
这个答案有帮助吗?
得分 1
添加一条评论
You'd be better to get a new dual band usb AC wifi/bluetooth 4.0 combo dongle for a little more (prob about 50.00 and this antenna only is 27 and tax plus shipping and also used.....) and you'd have AC wifi and newer Bluetooth, but it is a usb connection instead of internal so unless you REALLY want internal only you'd gain much more with a newer AC wifi/BT 4.0 dongle for a few bucks more.
这个答案有帮助吗?
得分 0
1条评论:
Most WiFi/Bluetooth dongles don't support MacOS so that won't really help here.
The posters focus was on Bluetooth not WiFi and he was looking for a more powerful internal antenna which doesn't exist.
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 334
