跳转到主内容
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
27 个问题 查看全部
Telesccopic lens will not retract on the Coolpix S7000
Telescopic lens will not retract when camera is turned on or off. The entire telescopic lens stays extended.
Error message says "Lens error. Try again after turning the camera off and on".
I have tried to remove the battery, memory stick, turned on off multiple times.
Thank you,
Jeff
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There are a few simple things you can try documented at https://therestartproject.org/wiki/Compa... but if none of those work then I'm afraid you may be out of luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 332
