How to fix my beanie boos noes
my dog ate my beanie boo's noes and I want to fix it but how?
Hey Casey,
Check out this guide. It has a couple different ones in it, but I think the most helpful for you would be to check the button one. Then, you can sew on a new button to your beany-baby's nose.
Hope this helps,
-Tanner
这个答案有帮助吗?
If it pulled it off, you can always try to sew it back on but if it chewed it up, you could always replace it with a small button or bead!
这个答案有帮助吗?
I have the same problem this morning my dog which chewing on my kitty OK she fell off the bed so I don’t wanna put a bead a bead button I can’t see her without her cute little pink nose I’m gonna see how much fabric Is left around her nose thenI’m going to try sewing it also liquid stitch which is what my mom is going to have to do
这个答案有帮助吗?
My dog ate at it but the nose is still on and she ate at the plastic piece
There are often Beanies at thrift stores and garage sales. You may be able to find a replacement nose on another Beanie being sold for a small price. The repair is a little fiddly, but someone who sews should be able to make the replacement. Of course, then there will be another Beanie without a nose… But maybe that is what some little bitty button is for.
这个答案有帮助吗?
You start with a double whisky neat, to reduce jitters. Go through your other, in tact, beanie babies and scavenge for better, in tact, appendages. Take said appendages such as a nose or arm and replace the &&^&@@ up appendage with the newly, in tact, appendage. Finish with another double whisky neat for a job well done, you deserve it!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 2,539
5条评论
Was it the plastic part only? Or did your dog chew off the whole nose (like the fabric and some stuffing)?
由 [deleted] 完成的
mine is the plastic part and i want to fix too i dont even have the piece
由 WrathfulSadness 完成的
Does anyone know where to find just the nose part?
由 strdms 完成的
Maybe u can use black stitch things to so it back
由 Momo 完成的
@WrathfulSadness mine was the plastic to, i was thinking we stich a black so to fix it
由 Momo 完成的
