跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
Ipad2 screen turns on, sometimes flashes green.
Hello,
I dropped my ipad, it may have hit something, but it has a microelectronic case. At first every time I pressed the home button to turn it on, it just dimly lit the screen and a dropped it on the carpet a bit, with no effect. Then, I knocked on it with my knuckles and it started flashing yellow one time after I pressed the power button while it is on. I saw an answer to smack the pack, so I gave it the good old spanking. It sort of worked. Now, when I press the home button to turn it on, it flashes all green for a split second, showing also a lash of the normal background and home screen. When I press power button to turn off, it flashes green for like .1 seconds, flashes heavy green tinted background for .3 seconds or somewhere around there, and then flashes all green for .2 seconds, then turns off. I am a kid, so if you could provide the least complex answer possible, that will be awesome. I will get my dadto take it to the shop if I have to open it. Thank you for taking your time to read this and I hope my iPad is ok :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Either the display cable needs to be reseated for the screen or the LCD display needing to be replaced. You will have to take it to a mobile phone repair shop to get them to open it.
这个答案有帮助吗?
得分 3
1条评论:
Ok I will tell my dad to bring it to the shop. Thanks :D ill accept the answer if that works
完成的
添加一条评论
添加你的答案
Mason Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 285
