跳转到主内容
加入维修社区 - 创建账户
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Not charging, screen flickering
Hi all, so I'm working on a friend's Note 10.1 2014 edition, and she brought it to me telling me it wasn't charging. I tried different cables, but the same thing happened - the battery symbol would show up (as drained) first, then the screen would start flickering. I left it charging for 2 hours and not even one bar would show up.
Then I found this forum with the exact same problem. https://forum.xda-developers.com/showthr...
So I looked into the USB charging port and sure enough, the pins were bent and damaged. So I ordered a new part, followed the guide here on replacing the charging cable inside. Plugged it in after the change - same exact problem.
I'm stumped and I can't find any others having this issue. What do you think? Bad motherboard?
Thanks -
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
Change the adaptor, and if you don't mind then the cable too
Anil
这个答案有帮助吗?
得分 0
3条评论:
My sons is doing the same thing I have tried everything the screen used to go completely black if it took a knock or something but I fix that problem by taking it apart I have literally tried everything I can think of but nothing is working charged it all night just keeps flickering
完成的
I had the same trouble. I think it is the outlet i was using. Took it to my friends house using same charging plug and cable. It charged right up. No flickering. and kept the charge all day
完成的
No use! Doesn't work.
完成的
添加一条评论
Factory reset it and when it asks you, volume up:continue
Volume down: cancel restart ,press volume down
it should work tell me if it does not
这个答案有帮助吗?
得分 0
添加一条评论
Thanks to everyone who helped on this. I tried these steps and none of them resolved the issue. My friend has since passed, so this is no longer an issue, but hopefully others who are experiencing this issue can be helped.
这个答案有帮助吗?
得分 0
1条评论:
mind is doing the same thing. I had it on while i was sleeping and it crashed. I woke up to a charging screen and the tablet unresponsive. i brought it down and stuck it on one of my computers whent e usg cable and its doing the same ting. Tryed to reset it but its not doing that either. I suspect its done, lived its life. Ill probably send it to samsung and have them do something with it. thanks for listening
完成的
添加一条评论
Exact same issue. If at all I have to use it, then I need to have it plugged-in always like a desktop PC. Funny that the recovery mode/menu works without plugging!
这个答案有帮助吗?
得分 0
3条评论:
The battery percentage always stays as 0% and charging when plugged-in and the tablet shuts down immediately when unplugged.
完成的
I just tried switching to a different outlet like the person above recommended, and that did the trick. 😎 Thanks!!
完成的
Dear George mixco . I'm sorry for your loss. I'm familiar with loss of loved ones . My condolences . God bless
完成的
添加一条评论
If your screen is still flickering, try adjusting your brightness settings, and disabling the adaptive brightness feature. Corrupted data in the system on your device can sometimes cause the screen to flicker. Clear the cache on your device, then check if the flickering continues.
Greetings,
Peter
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
George Mixco 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 69
总计 36,270
