跳转到主内容
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
28 个问题 查看全部
Problem with my HARD DRIVE. It's not being recognized!
Good afternoon. I recently bought a laptop "HP 250 G6" brand new. When i booted it it was okey. After 3 hours when i tried to open it, it said "boot device not found". I called HP support and they said to run a hard disk diagnostic. I did it and it said that there is no hard drive inside. I sent it back to them to send me a new laptop "DOA" but they said that they also have to see the problem and then they are gonna send me a new one. They sent me an e-mail saying that their diagnostic didn't find the problem and that the hard drive is ok. Do you have an idea of what could have happen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Run a utility like Hiren's Boot CD and see if the hard drive shows up in HDAT2. If it doesn't show up there, there's an issue with the replacement laptop. While this usually isn't sufficient on it's own with HP, it will give you some leverage to get another replacement laptop. More then likely it's a dead hard drive.
What I would do with HP is run that utility and check for the hard drive. If it doesn't show up, then I'd run HP Diagnostics and see. If you have an issue and it comes up in two places, HP's hands are tied and they will have to do something. If you have another issue with the 2nd replacement I'd return the laptop and find something else.
这个答案有帮助吗?
得分 2
添加一条评论
The cable could be disconnected, or the connector on the hdd could be damaged by dropping or moving the laptop but thats very unlikely.
这个答案有帮助吗?
得分 1
2条评论:
Is it possible for the HDD to be dead?
完成的
thats odd. I hate in when something happens and you try to show someone else then it does not do it when they are watching. but thats really weird with an HDD. they usually die and stay dead. maybe it was a software issue?
完成的
添加一条评论
添加你的答案
Roronoa Zoro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 640
