跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Black spots on tv and getting double image..
I have a 70" 3 yr old vizio tv. Turned it on one day and had big black spots in the corners and a double horizontal picture. Not sure if I should keep it or try repairing it, I just don't know what the problem could be. Someone told me my LED screen may be bad and you can't buy replacements, is that correct?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Often, with bad screens it's not even worth fixing. However, this looks more like an image issue to me, considering the double image. Can you give me the model number so I can look at the boards that TV has? One of them is probably the issue.
这个答案有帮助吗?
得分 0
4条评论:
It' a Vizio E701i-A3E smart TV, thank you....
完成的
Ok, so sounds like this is a very common problem with your model. It was actually recalled by Vizio back in 2013 - you might call and see if they are still doing free repair or replacement. This would be ideal because it would be free and you wouldn't have to worry about accidentally damaging something.
855-209-4106
https://hdguru.com/vizio-issues-a-recall...
完成的
I'm going to call Vizio first thing and ask. If by chance they won't honor the recall do you think I should replace the circuit boards inside seeing it may be just a bad chip?
完成的
Did they honor it? If not they might be able to tell you exactly where the issue would be.
完成的
添加一条评论
添加你的答案
Mark Grant 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,873
