跳转到主内容
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79 个问题 查看全部
Why dose my car crank normal but no start
I have a 94 toyota camry le it was driving just fine and it just died on me when i was driving thought i ran out of gas but now it has gas and still no start. I was told there was no spark at the sparkplugs. After new sparkplugs, sparkplug wires, distributor and cap, and a few other things it still wont start. I dont have the money to take to a shop and no one to help at least no one that know what they are doing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Sadly this is a harsh lesson, not to be mean. When someone says no spark at the plugs, unless you actually can't see one. Don't believe them.
First things first, check all your fuses to make sure they are in good condition. It could be as simple as a blown main fuse.
Check your battery connections to make sure they are tight, and not loose or corroded. (Green or white stuff on terminals is bad.)
Document: This is the ignition part of the repair manual for your vehicle, tells you how to go through the check list to determine what is good and what isn't. Ignore what you've already fixed. It also gives all the values and what tools are required and how to go about doing the checks, on the ignition systems. I hope it helps you.
这个答案有帮助吗?
得分 2
4条评论:
Would this repair manual work for my 91 Camry also?
完成的
As long as the engines in both cars are the same, yes it will work. aka 3SE or 5FE for example.
完成的
How about the relay fuse
完成的
@danfine818 Your main fuse is either at your battery or in your main fuse box. It will either say Main or Engine. Could be your EFI fuse if it has EFI. Take a relay of the same type usually the horn relay and switch it out with the one you suspect. If it works there is your problem, if it doesn't then it isn't the fuse.
It could also be your igniter if you haven't changed that. Bad fuel pump will cause a no start issue, but you'll still have spark.
完成的
添加一条评论
添加你的答案
Lisa Perrin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,097
