跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
My MBP 15 - 2011 shuts down, already changed battery and reset SMC.
Hello!!
Just purchased a faulty MB Pro 15 Early 2011. It works perfectly when plugged to AC adapter ( I use an original ) but when running on battery it randomly shuts off and I cannot then turn it on. I have to push many times the power button and then ir turns on, as a result I lose all the work going on....
So I got a new battery, but still the same problem. Reseted SMC and the same. I downloaded coconut battery and ran terminal and I get this:
Last login: Mon Mar 19 15:51:43 on console
Juans-MacBook-Pro:~ juan$ pmset -g batt
Now drawing from 'Battery Power'
-InternalBattery-0 35%; discharging; 0:49 remaining
Detailed failures: "Externally Indicated Failure", "Safety Over-Voltage", "Cell Imbalance", "Discharge FET" present: true
Please help me, whats going on, what can I do? I read on some other tread something called the battery controller chip, this might be the problem?
Any ideas?
Thanks!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
In your first line, you say you bought a FAULTY machine……..
If the last owner cannot tell you what they did to it, to cause the fault.
You can’t expect someone on here, to tell you exactly whats wrong with it.
You need to send it to an apple repair technician to be looked at.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
juanguillermo.velasco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 107
