跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
MacBook Pro shows no signs of power
I have a 15" Macbook Pro retina that wont turn on. Charging light is green, only when I unplug the battery the charging light will turn orange, but either way the unit does nothing when I press the power button, no fans no sound no power. Any ideas out there what this problem may be? Tried SMC and PRAM resets
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
There are many things that would cause this problem. Normally the charging light should be green without the battery plugged in or the battery is full. If the light color as you said, this could be the power module (where the charging cable connects to the laptop).
Has any liquid been spilled on the keyboard, or has any liquid got into the laptop? If any liquid spilled on the keyboard it would damage the keyboard so that the switch can’t connect the power to start the laptop.
You can try to disconnect the keyboard and reconnect it. If the logic board failed I am afraid that there is nothing you can do apart from having it repaired or replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amber Savoy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 174
