跳转到主内容
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
167 个问题 查看全部
Galaxy S8+ Battery temp -20 celsius.
Hi
My phone says that the battery temp is -20 (tried with different apps )
When I try to charge it says: Charging paused, battery temp too LOW.
I have tryed to change the daughterboard, but still same problem.
Also tried with another battery.
I can't see any water damage.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Someone who has an idea?
完成的
So I just had this problem. Tried new battery, same issue. But when I completely reassembled the phone (I was testing phone after screen replacement so I didn't have it all put back together when I was having this problem) everything charged find. No low temp issue. Something on the loudspeaker and other parts seem to cause problems if they are not connected. Hope you have the same problem.
完成的
Great find! Hope this helped OP too.
完成的
添加一条评论
4个答案
最有帮助的答案
Also seen the NFC Antenna cause problems charging with USB, why Wireless Charging would affect USB Charging, dunno, but replaced an S8 & a S8+ Battery, both wouldn't charge without NFC completely installed.
这个答案有帮助吗?
得分 1
添加一条评论
Was that other battery you tested known to work in another phone? If not the problem may be with each battery's on-board Battery Protection Board, not your phone. Try a new battery or a known working one, hopefully that will fix it.
这个答案有帮助吗?
得分 0
1条评论:
Ordered a new battery and replaced the old one, but still same problem.
完成的
添加一条评论
So I just had this problem. Tried new battery, same issue. But when I completely reassembled the phone (I was testing phone after screen replacement so I didn't have it all put back together when I was having this problem) everything charged fine. No low temp issue. Something on the loudspeaker and other parts seem to cause problems if they are not connected. Hope you have the same problem.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem testing the replaced battery before remounting the nfc antenna. Problem solved remounting the nfc antenna. Ciao
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lars 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 19
总计 1,651
