跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
iPhone SE won't display after lightning connector replacement.
So I was wondering if I could get some advice. I opened up and replaced the lightning connector on the iPhone, but after testing it the headphone jack wasn't working. So I decided to open the iPhone again to see if there was a problem with which I installed the connector I found none. The problem is now the screen won't turn on and I have no idea if the connector got messed up or the screen is broken. I connected the iPhone to my laptop and iTunes detects the iPhone and even it's name, but I haven't been able to get any other response. I am stumped as to what the problem could be has anyone else had a similar issue?
P.S. I noticed that the cable battery cable seems to have some 'styrofoam' looking part in it and I don't know if it's relevant.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey have you tested a hard reset?
Hold power button and home button the same time up to a minute, relese when you see the apple logo.
If that dosent work, I would open it up, relse the plate over the connectors for the battery and lightning and look if anything looks damaged on the board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eli 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 83
