跳转到主内容
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
56 个问题 查看全部
What adhesive do I need for LG G6 screen replacement?
I purchased a replacement screen/digitizer for the LG G6. There doesn't appear to be any adhesive on the glass back or in the package. What adhesive should I use to install the new screen to get it as water tight as possible?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I used the below product and it worked great. Very thin, did not result in a 'raised' screen or back glass. Very sticky. I was careful to remove all the old adhesive from the inside frame bezel area for the screen. I also put several vertical strips beneath the screen to help.
Eco-Fused Adhesive Sticker Tape for Use in Cell Phone Repair - 2mm Tape - also including 1 Pair of Tweezers / Eco-Fused Microfiber Cleaning Cloth (black) $6.99
https://www.amazon.com/gp/product/B00BXY...
这个答案有帮助吗?
得分 2
1条评论:
I'm not affiliated with the supplier. I just didn't get an answer, tried this stuff, and it worked.
完成的
添加一条评论
添加你的答案
Russ 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,140
