跳转到主内容
Can be identified by Serial Number: 31.2000.2338851 Manufactured by Keurig
20 个问题 查看全部
Keurig K10 Mini brew switch intermittent problem
The brew-switch on my K10-Mini does not always change to flashing red (stays flashing blue) when I push it. Pushing multiple times normally solves the problem, but it is getting worse. The machine is two years old and brews one cup per day on average.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sounds like you might need to descale your machine. Crap builds up inside the boiler and prevents correct operation. If you have your manual it will describe how it is done.
Otherwise go here
这个答案有帮助吗?
得分 0
添加一条评论
Thanks. Could you please explain how scale in the boiler could prevent the heater from switching on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Webb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 198
