跳转到主内容
加入维修社区 - 创建账户
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Battery Tab Not Present
Quick question, I am tryin to replace my MacBook Airs battery and there isn’t any pull tab. What alternatives should I use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Are you referring to the tab to unplug the battery cable from the main logic board? If so, I'd recommend something that can gently but firmly pull or pry the plastic of the plug so no strain is placed on the cable itself.
Regardless of which tool you use, you'll need to be careful not to damage the plug or cable.
完成的
添加一条评论
1个答案
最有帮助的答案
Hold on here! This battery is screwed down. Review this IFIXIT guide: 2013中期 MacBook Air 13" 电池更换. Even the latest version still has screws.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tim Mota 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 360
