跳转到主内容
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
48 个问题 查看全部
Camera glass popped out
My phone is xiaomi Mi5 and recently camera glass is popped out but its not broken.
here is the picture of what happened :
Glass and phone
i still have the glass i just don't know how to stick it back !
can i use glue ?
if yes what kind of glue?
what things i should know before using glue?
what are other option other than glue?
Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is very risky, you could get glue on the lens but use an adhesive if you can find one, if not, then try a hot glue gun, but this should be a last resort, at this point contacting xaiomi to ask them what to do is probably the best idea
这个答案有帮助吗?
得分 0
2条评论:
What kind of adhesive i should use?
完成的
Well, idk, who knows, newegg has a lot of stuff on it, if you can measure the glass and find an adhesive with the same diameter, if you can't try a hot glue gun with a very small tip
完成的
添加一条评论
添加你的答案
Ramin Dashti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 185
