跳转到主内容
Repair guides and support for a wide range of radios.
245 个问题 查看全部
Boston Acoustic Horizon Solo Volume Control
The volume knob on my Horizon solo just up and quit functioning one day. Everything else still works fine, but I am unable to adjust (or display) the volume. This seems to be a common problem, as far as I can tell, but I have found no solution. I have tried:
Soft reset (did nothing)
Other sites recommended adjusting volume to 00 and then holding down volume control for 10 seconds. I was able to get the volume down to 00 by repeatedly plugging it in and adjusting volume down one notch at a time (I am stuck at level 24...........when I can manage to get it to display volume level)
I cracked open the case to I could attempt to spray the volume knob stem with some tuner-cleaner, but the access to the controls seemed a bit difficult to reach without some sort of guide to tell me what to do (and what NOT to do)
So as it is, I am stuck with a clock radio with excellent sound (If I like volume level 24) and absolutely no volume control. I hate to brick this thing......I can't really afford to replace it right now.
If anyone has a remedy for this situation, I would greatly appreciate any input I can hear.
THANKS!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
I found this on the Boston Acoustics website:
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments who wish to set a maximum volume limit on the radio. To remove this volume limiter, follow the steps below:
  • Turn the unit on
  • Turn the volume down to minimum, 00 volume
  • Press and hold power for 10 seconds until volume numbers flash
  • Turn the volume back up to 50 (max volume)
  • Press power again to verify new max volume position
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Trey Coye 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 32
总计 406
