跳转到主内容
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
131 个问题 查看全部
No power after screen replacement
I've replaced the screen on my iPad Pro 12.9 (1st gen) but it doesn't appear to be charging at all. Also, I had to replace the home button because I broke it while taking the screen off. I've checked to see if I unplugged something but I can't see anything.. I've attached pictures. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
Just for better insight, what tools did you use to pry the old screen off? Also where was the screen purchased from?
完成的
I used the tools from iFixit. I used a heat gun instead of iOpener because I found iOpener didn't help at all. Even the heat gun had issues getting it loosened. And, I used this screen here: https://www.unionrepair.com/replacement-...
完成的
Cool. Are you able to get me a close up picture of what the 2 little iPad LCD/digitizer connectors look like on the motherboard? Would also like to know if you used any metal tools inside the iPad while the battery was connected (anything other than a screwdriver). Also check to make sure that you put the screw that holds the connection between the motherboard and the battery back on if you took it out.
完成的
I'll add a close up, let me know if this is not what you were asking for. I may have, probably did at some point. Are you worried about a short with that? Yes, I remembered this after I had tried to put the display on so I had to take off and put the screw in and then try to plug in display. But, I've had an issue with the display though because the ribbon cables were kind of loose and then the connector for the ribbon cable to motherboard broke. They were very difficult to get in and bent and then broke :( I'm emailing the manufacturer to get a replacement.
完成的
Ok for sure. I would try to see what the manufacturer says, otherwise, your iPad looks clean and if there is a short, which I wouldn't believe would have happened if you're using static band, plastic tools, etc. See if you can get another screen which is most likely your issue here.
完成的
显示更多的1条评论
添加一条评论
1个答案
Did you disconnect your battery?
If no please do so you can get there on top and place a pick under te connector. Let me know if that works.
这个答案有帮助吗?
得分 0
1条评论:
Yes, I followed instructions from iFixit
完成的
添加一条评论
添加你的答案
Jonathan Holland 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 724
