跳转到主内容
The 12-inch screen laptop was first sold in mid-2006, and was considered well-equipped, powerful, and ultraportable.
5 个问题 查看全部
When I connect the laptop to the power it does not power on or charge
when i connect the laptop to the power ,does not power on or charge, the laptop work fine when the battery was have charge, but later stop work the power adapter, and i check the adapter and is does have power, what can be the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
A very good chance that the jack/socket that your power adapter plugs into is loose or faulty. The easy test for this: Make sure your power adapter has electricity. Plug your power adapter into the jack on the laptop. While watching the power/charger indicator lights gently move the adapter's plug in the jack. If you can get either light to flicker or stay on the problem is the adapter jack/socket on the lap top. Not many people have the skills to replace this themselves. You may want to take it to a repair shop. If you believe this is a job you can tackle here is the part for a reasonable price.
http://www.amazon.com/OEM-POWER-M1210-M1...
Here is Dell's online service Manual for your laptop.
http://support.dell.com/support/edocs/sy...
这个答案有帮助吗?
得分 7
添加一条评论
添加你的答案
kitozo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 2,284
