跳转到主内容
Released in 2013, identified by model number: RZ03-0038, Mechanical Gaming Keyboard and product number: RZ03-00381900-R3U1.
10 个问题 查看全部
Water damaged Razer blackwidow Ultimate 2016 down aroow
So a few months ago I spilled some soda on my keyboard. I have contacted razer support team and they said your warranty doesn't cover water damage so I took my keyboard apart and dried it with paper towels then let dry in front of a fan for 2 days and all my keys besides the down arrow key.
I tested my switches with a multi-meter and the switch it self seems fine its sending power but it's not sending input to the computer though so I would like to figure out what I can do to fix my down arrow key
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
i would start by removing the keys, and soak the board in 99% isopropyl, then scrub it with a new toothbrush. this will break away any corrosion, without causing the metals to oxidize. blow dry for a minute, then let sit for 30 minutes. see if that gts you key running. The fact that the switch is working, but the signal wont send means the damage to the trace could be nearly anywhere. finding it would be very difficult.
这个答案有帮助吗?
得分 1
5条评论:
Do you mean remove the keycaps or the switches them self
完成的
keycaps. sorry for the miscommunication.
完成的
Its alright just wanted to make sure and thanks for the information ill be doing this next weekend when I have time
完成的
please keep in mind, this is only one possibility.
there is also a likely scenario where the short from the water has fried out a component used to process the signal. cant say without actually trying this first though.
完成的
Alright thanks for the information
完成的
添加一条评论
Did you ever find a solution to this issue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dakota Milam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 7,146
