跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
possible to solder power button
Hi all,
I have a 13inch Mac book air which the screen is broken.
I wish to turn this Mac book air to a pc media.
I have 2 question to ask..
1) is it possible to solder a power button into the board?
2) is it possible to solder more USB port into the magsafe 2.
Thanks for the help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You can solder a basic button & 2 wires to the power-on pads on the motherboard.
http://www.insidemylaptop.com/turn-on-ma...
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Soldering a power button to the board is easy...
But why?? Is it not turning on if you hit the power button but starts if you hit the power pads? If so your trackpad / flex is probably messed up.
More USB ports? No practical and probably not possible.
这个答案有帮助吗?
得分 3
6条评论:
Without rewiring the PCH it's not possible to add USB ports.
完成的
Hi thanks for the reply.
I find that replacing the display is too expensive..
So I wish to convert the MacBook air into a tiny media box. And just permanently stick it next to my smart tv with perm power.. so have to diy power button. And adding more usb port to the Magsafe Board - 923-0125.
完成的
You can't add something mechanically if it still isn't electrically connected back to the USB hub which is part of the PCH chip.
Just plug in an external hub into your USB port you do have.
完成的
Thanks dan..
Any guide on which pin to solder for the power button?
完成的
Sorry guy, don't have any guide for you. This is beyond what we are able to offer. The best thing I can recommend is locating the schematics and layout drawings for your system to work off of.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
imjust ajoke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 606
