跳转到主内容
Android phone from BLU, released September 2015.
9 个问题 查看全部
Headphones not picking up phone calls
Why is it that music works fine over headset whether wired or Bluetooth but when I try to make a phone call headset doesn't pickup anymore, again whether wired or Bluetooth. This feature is important to me and it used to work all the time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @notbob ,
Are you using the 'phone' app to make calls or a 3rd party app?
If using the normal phone app, try starting the phone in ''safe mode'' and check if it works OK.
If it does work OK then a downloaded app is the cause of the problem. The trick is to find out which one.
If it still doesn't work try a factory restore, (also known as a hard reset), using the phone's factory restore feature.
Before you perform a factory restore, backup the phone first.
Be aware that a factory restore will erase all your data and downloaded apps. It will be restored to its' factory default condition. That's why it's important to do a backup first.
Once the factory restore has been completed, check if the phone works correctly. If it does then restore the phone, using the backup that you made earlier, using the phone's restore feature.
Once the restore has been completed, check the phone again to see if it is still OK.
if it is then the restore (reset) has fixed the problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paul Newbert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 212
