跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
touch not working after battery replacement
Hi,
I have a iPad model A1395 with defect battery. So i replaced with new battery and tried to charge it and it works fine. But then i want to test the touch before i mount the screen back with adhesive... now touch not working and only home-button is working.
Shouldn't the screen work while it's open like iPhone screens when its not completely closed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Hello Ibrahim Ibo, If you opened the iPad there are ribbon cables to make the touch sensitivity work i recommend that you reseat the cables inside the iPad then try again if this doesn't work clean the connection then try again.
Hope this helps
-Activoid
Update - the cable should look a little like this
这个答案有帮助吗?
得分 0
14条评论:
can you please show me picture of this cable?
完成的
tried to disconnect the cable at both ends, still no responsive :(
完成的
have you tried cleaning the gold connections on both ends such as the Logic board connections and the ribbon cable connections
完成的
what can i clean with? 100% alcohol?
完成的
I wouldn't pour it directly onto the board but put just a tad bit on a cotton ball and just dab it onto it that should work just fine then let it dry for around 15-30 minutes don't wipe it because then you can risk damaging the connections
完成的
显示更多的9条评论
添加一条评论
When opening the iPad did you accidentally tear the flex cable for touch glass? Inspect carefully.
If all looks good. Try slowly bending the touch glass around while touching and see if you get a response at a certain bend.
Next make sure the touch flex is properly seated in its connector on the logic board and that no pins were bent
这个答案有帮助吗?
得分 0
添加一条评论
There you go, i taked two pictures. One of the Home button component, and one of the 2-pin over the charger-component
这个答案有帮助吗?
得分 0
添加一条评论
Make sure the cables are not torn or ripped, they can rip pretty easily. If they are damaged purchase a new screen, they're relatively cheep. If they're not damage take the cables out and put them back in again. There is a white line on the cables
make sure the white line is parallel to the plastic screen connector. Also make sure the latch on the screen connector is closed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ibrahim Ibo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 210
