跳转到主内容
Model A1199 / 2, 4, or 8 GB capacity
85 个问题 查看全部
问题已关闭
Ipod is not charging?
I think I have a IPod Mini. Not sure. The model # is A1199, 2 GB. The battery ran out,I bought a dock conn. cable and plugged it in. After several hrs., it shows "do not disconnect" and it has a red circle with line thru it. Should I do something else? thank you a Senior Lady. Claudia
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your iPod may very well be charged -- the "Do not disconnect" notice may just mean that the iPod is mounted on the computer and thus should not be unplugged yet. Open up iTunes to see if an image of the iPod is in the left hand column. If it is, click on the eject button to the right of the iPod image (it's the circular button with the triangle on top of a line). Then the "do not disconnect" message should go away and you should be able to unplug your iPod. If that doesn't work, shut down your computer. When it's completely off, unplug your iPod.
With your iPod unplugged, you should be able to determine if it actually charged up.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 11
总计 2,248
