跳转到主内容
Model A1320 / 8 or 16 GB capacity
156 个问题 查看全部
Did I just ruin this iPod?
I was trying to remove the battery from the logicboard, and two little brown pads came off of the board , did I just ruin this ipod?? It's my sons and he's going to be heartbroken. I can't afford to get another one please help me fix this someone.
Update (03/12/2018)
Attached are pictures of the solder connections on both the battery ribbon and board
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
if the two little brown pads that came off are fabric-like then you should be fine, if it is anything else i'm not sure
这个答案有帮助吗?
得分 0
2条评论:
The pads were the point on the board that the battery ribbon was soldered to
完成的
Can you add a picture? if its the pads that came off, you may (with a little bit of soldering experience), be able to run a jumper to the pulled pad from the trace its connected to.
完成的
添加一条评论
if theres any solder left on the board you can use carefully rebuild the connection...if not youll need to find an alternate solution to charge...you can get a new logic board and battery for under $20 online .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
plantdad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 18
总计 132
