跳转到主内容
苹果的第四代无线键盘 发布于2015年10月 型号A1644
Magic Keyboard 2 can not connect it via Bluetooth
My Magic Keyboard 2 can not connected via bluetooth, can only connected via usb, it just like dead totally after unplug usb cable.
Before this happened, I were cleaning it, and claped it a little bit, then it can not connected via bluetooth, usb is fine.
I wonder if the wire between battery and board is disconnected or something.
Is anyone knows what is going on ? Do I need to tear it down ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Did you clean it with a sanitized wipe? I've seen them cause liquid damage of keyboards.
完成的
No, no water inside
完成的
I have the same problem, I did not clean the keyboard, but bluetooth connection stops working, only works via USB
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @kylebing ,
You may have 'bounced' the battery flex cable plug out of the connector on the pcb, when you 'clapped' it.
Here is a link to the ifixit 妙控键盘拆解 guide.
Scroll down to Step.6 and hold your mouse pointer over the 3rd image to view the connector.
The guide is for the Magic Keyboard but hopefully it will be similar to your keyboard and this will still be of some help to you as you will have to open your keyboard to ascertain what the problem actually is.
这个答案有帮助吗?
得分 1
1条评论:
Thanks, I have opened it and didn't find the problem is. I think it is caused by the bad battery.
完成的
添加一条评论
添加你的答案
Kyle Bing 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 59
总计 7,806
