跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
Very dim screen after damage?
So about six months ago I accidentally dropped a glass of water on my Macbook and I took it to my local apple store and they told me it had water damage and needed massive repairs and I should just buy a new one because it would be cheaper, I didnt have the money for that so I took my broken laptop home and left it in my wardrobe for six months and the other day I was cleaning out my wardrobe and found the charger for the laptop and wanted to sell it but didnt know if it was workable as it got slightly wet in the water incident, I thought maybe I could plug it into the broken Macbook even though it doesnt work maybe somehow it would work and upon plugging it in the charger lit up! and then I left it for a good few hours to charge and when the charger went green I tried turning the laptop on and it worked but the screen is extremely dim, I was wondering is this an easy fix? or am I going to be told once again that the water has damaged it too much for it to be under $300? thank you for your time :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try f2 or fn f2 on your keyboard. If that doesn’t help you can try removing the back cover and check led cable connection make sure it’s clean.
这个答案有帮助吗?
得分 0
4条评论:
Are you talking about the bottom of the laptop? remove that? and how to I know what the led cable is?
F2 and FN F2 didn't work.
完成的
Yes, remove the bottom cover. Led cable should be by bottom left hinge. It is a large flat cable with about 30 pins.
完成的
This job requires a torx t5 screwdriver. Do not attempt to open it with any other tools as this could damage the screws.
完成的
torx t5 doesnt fit into the screws.
完成的
添加一条评论
添加你的答案
Jenn peg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 213
