跳转到主内容
Repair and disassembly guides for Sony DVD players.
20 个问题 查看全部
Load/Eject door will not open, cannot load DVD
Sony CD/DVD Player DVP-SR210P Load/Eject door does not open. It sounds like it is but nothing visable with the cover off is moving. What can I do to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Just fixed mine. Belt for tray eject was stretched & just slipping on the motor pulley. Dug through old bad PC CD/DVD drives & found a belt that fit. Loads & ejects tray like new now.
完成的
Harbor Freight sells those general purpose O-ring variety packs, there might be one of the size needed in there?? Original drive belts are square, but any rubber O-ring of close size needed should work as long as the problem is not something mechanically jamming the tray.
完成的
添加一条评论
1个答案
已选择的解决方案
A stuck disk tray is fairly common. See https://therestartproject.org/wiki/CD_an...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vickie Belt 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 31
总计 10,390
