跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Not Charging after replacing battery
I was trying to replace the swollen battery in my daughter's iPhone 5s with a recently purchased and functioning iPhone 5c battery. I have replaced batteries and screens on the iPhone 5c devices several times, so I am familiar with the care needed to not damage ribbon cables and connectors during the swap. After replacing the battery though, her iPhone will not charge. I removed the battery and put it back into the iPhone 5c and it charged just fine. Also, when the battery is charged, I was able to sync the iPhone 5s to iTunes and saved a back up of her files, photos and music. I checked all of the connections several times, including the small single wire that plugs in near the battery plug and the plug from the charging port. I do not have a USB Ampmeter to properly test it as I am a DIY type. Any thoughts on what to look for?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Either the charging port is busted or the Tristar chip needs replacement which requires micro-soldering work done on the phone. You can find reputable repair shops that offer a no-fix no-fee model to get them to fix it for you.
You can quickly test tristar by unplugging the battery then plugging the charger in and see if it shows apple logo or not, if it does not then the tristar chip is not. Usually I would test another charger port if possible to rule that out.
这个答案有帮助吗?
得分 1
2条评论:
So, without the battery installed, if I plug the iPhone into the lightning cable and charger to power, I should still get the Apple logo? I tried it, I put the screen back on but did not reconnect the home button and plugged it into charge, I did not get the Apple logo, that means the chip is busted. Is that correct?
完成的
Yes if you can't get Apple logo to appear when screen is connected and battery unplugged Tristar chip needs replacement.
完成的
添加一条评论
The 5C battery is not the exact same as the 5S battery even though it does fit. Try ordering a 5S battery and see if that fixes the issue.
这个答案有帮助吗?
得分 0
1条评论:
They both work vice versa On 5s and 5c, that's not the issue.
完成的
添加一条评论
添加你的答案
Donny Sanders 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,795
