跳转到主内容
The Saturn Relay was the first and only minivan from the Saturn brand of American automaker General Motors and was built alongside its sisters, the Buick Terraza, the Chevrolet Uplander, and the Pontiac Montana SV6.
29 个问题 查看全部
driver side door window came out of the track
driver side door window came out of the track,, the window had frozen to the felt and when I pushed the button for it to go down the window stayed up but the track went down.. how can I get the window back on the track???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The window has parted company with the mechanism that determines up/down movement.
What i would do next would be to remove the glass window completely then the internal door cover/lining then remove the polythene to expose the mechanism ...now keeping fingers away try the window control button to confirm if the system is operating normally and if so! the next step is to determine just how the glass was fitted . This may be all that is required.
NB: Your owners manual may not give you any details with this procedure but you can buy a H----- MANUAL for your model of car which should give a more detailed idea of what your internal door looks like.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Judy Reyes 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 8
总计 61
