跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
home button assembly and cabe
I ordered a home button assembly for the ipad 5 from ifixit. It did not include the home button gasket. Am I supposed to use the old home button gasket. Thanks
Allen
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
thank you so much
完成的
添加一条评论
2个答案
已选择的解决方案
Thanks so much for your help
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Take a look at Step 48
“Press the home button from the external side of the digitizer to break up the adhesive holding it in place.
Apply pressure slowly. The adhesive is attached to a delicate gasket that will tear easily.”
If the gasket is secured to the old home button carefully remove it to be applied to the new home button.
Make sure the adhesive is warm with the iOpener or you may tear the gasket.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joe Gibson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 82
