跳转到主内容
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59 个问题 查看全部
What can I do to fix a pink/purple screen with a white vertical line?
About a month ago, I dropped my phone killed my screen and I had it fixed.
Last night while I was charging my phone, it fell!
When I picked it up the first thing I noticed is that it had a vertical white line that ran from top to bottom and the area where the line was located could no longer work.
Then I noticed some pink/purplish lines running in all directions on the screen!
Now the whole screen is a pinkish purplish colour and the part of the screen where the white line was originally located has started to turn black, it is slowly progressing and I am guessing that by the end of the day my screen will be completely black.
Also, my screen isn't broken!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Only solution is to replace the screen again.
这个答案有帮助吗?
得分 4
添加一条评论
  • sounds like you were playing a video.if you switch tabs during a tab many times it will come.remember,it might be 4 times
  • it could be screen problem
  • joining a meeting+playing a video ,it will come like that
这个答案有帮助吗?
得分 0
1条评论:
you`r screen will also off,please off it and on it again
完成的
添加一条评论
添加你的答案
thea sku 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 28
总计 9,632
