跳转到主内容
A model in the Q400A series by Asus. This model features a 14" display and contains a quad-core i7 processor, 8GB of RAM, and a 750GB hard drive.
2 个问题 查看全部
Will not charge. Bought a new battery. Bought a new charger. Will not
The previous battery would not hold a charge. Laptop would work when plugged in. Then stopped. Ordered a new battery and a new charger. The new battery worked until the charge emptied out. The charger will not charge the battery. What do I do now or where do I go to get it fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @gye7293 ,
Does the laptop indicate that the battery is charging when you just connect the charger to the laptop?
If not, as it doesn't start with the charger connected, then you may have a faulty DC-In jack.
It may be faulty or it may have become disconnected from the motherboard.
Here is a video that shows how to access the DC-In jack.
Here is a link to just one supplier of the replacement part.
It is not a recommendation to use them. It is shown to give an idea of the cost of the part. There are others online that may suit you better. Just search for Asus Q400A DC-In jack part to get results.
You will need soldering expertise and tools to effect the removal (if necessary) and replacement of the part.
If this seems too daunting, contact a reputable, professional laptop repair service and ask for a quote to repair the laptop. You already know the cost of the part. ;-)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lora 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 293
