跳转到主内容
Repair and support for ceiling-mounted bladed fans.
44 个问题 查看全部
My Ceiling fan only make humming sound but not moving, Light works.
Ceiling Fan light is working but fan only making humming sound but not moving? I have changed capacitor, checked pull switch and forward-reverse switch. Don,t know whats the issue here.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
最有帮助的答案
I don’t think it is a switch problem. When I change speeds I can hear the hum change. I took the light kit off to look at the capacitor. I ordered a new capacitor and like magic the fan started working again. I have a new capacitor. Next time it doesn’t start I’ll replace it. Until then ‘if it ain’t broke’.
Thank you for your guidance.
这个答案有帮助吗?
得分 2
1条评论:
I found my direction switch was the problem. I can switch directions a couple of times and the fan will start working.
完成的
添加一条评论
Hey mate, looks like the capacitor of your fan is not in a great shape. Consider changing the capacitor of your fan which has the same specs as of your faulty capacitor. If you have changed the capacitor already and its not working, then immediately turn of the fan and remove the capacitor you have just installed. The reason behind this is that you might have put a capacitor that is not in the range of your fan's rating, your fan will get damaged over time and ultimately you have to buy a new one.
Also try turning on your fan and then give it a push, If it works it is sure the capacitor problem.
这个答案有帮助吗?
得分 2
2条评论:
Thank you for your time and advice. I found the problem was a dirty direction switch. I cleaned the switch. Fan is working like it should.
完成的
I am sorry to not correctly guess the problem or point out. Apologies for the confusion made and thank you for replying!!
完成的
添加一条评论
Does it spin easily by hand when off? When on and humming, try and get it spinning by hand. Does it take off and start spinning? If so your capacitor may be bad out of the box (rare but happens) or might be the wrong capacitor. If it doesn't, or doesnt spin freely like it normally does, then the motor might be bad/have bad bearings.
这个答案有帮助吗?
得分 1
3条评论:
I have this problem. My fan spins easily by hand. Motor hums and changes when speed is changed but fan will not run. It has been this way for a year. Last year I went outside came back and fan had started working. Just turned it off to dust and it will not run. Still spins easily.
完成的
@fredric2 sounds like you need to open it up and check the capacitor. Alot of fan capacitors are square with up to 5 wires.
完成的
Thank you. That is what I was thinking. Nice to get a second opinion.
完成的
添加一条评论
It can also be a problem with the switch connection make sure all the wires are connected properly and make sure the switch is working 100%
这个答案有帮助吗?
得分 1
2条评论:
Thank you. I'll look into that also.
完成的
Found the problem was with the direction switch. When I change for the season I can work the switch a couple of times and it will start working.
完成的
添加一条评论
添加你的答案
Vikram Raj 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 124
总计 1,367
