跳转到主内容
adjustment height screw type on trackpad?
Hi,
I am trying to fix my trackpad not clicking anymore on a refurbished macbook pro 13" retina early 2013. I opened it up without any problem, but I can't seem to find the right screwdriver to unscrew the trackpad's height adjustment screw; a TR6 seem slightly too small and a TR7 too big. Do I need a special tool?
You can see the culprit in this picture, next to the thumb:
https://d3nevzfk7ii3be.cloudfront.net/ig...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
I may be wrong but I believe its a t6 hex screw but ill have a go on a trackpad and see if I can find out for you
这个答案有帮助吗?
得分 2
16条评论:
just tested definitely t6 hex maybe the screw was already chewed before you opened where was the device refurbished
完成的
So just to be sure, T6hex is the same as TR6 (torx security), there is no difference between a T6 and a TR6? Well i'll give it another try and see what happens then. Thanks Lewis.
完成的
apologies I meant torx and yes t6 or tr6 are the same here is the link to the screw driver
https://eustore.ifixit.com/en/Tools/Driv...
完成的
Well, after another try with my TR6 from the 64 bit driver kit, it seems that the screwhead has been stripped enough to prevent me from adjusting the trackpad. The macbook had the logic board replaced 3 years ago when still under apple care and I guess they messed the screw up when taking it apart somehow . Well, I'll try to get used to "tap to touch" for now I guess. Thanks again.
完成的
hmm thats odd the adjustment screw shouldn't be removed its a setting screw I believe the trackpads are quite cheap it might be worth just purchasing one.
完成的
显示更多的11条评论
添加一条评论
  1. Adjustment screw is T6 or TR6 - if it does not fit it is a stripped screw, which is very easy. They are like 5 bucks at an Apple repair store. Before you add it back to the MacBook make sure the threads are clean and no do not put on ANY oils.
  2. Take out the complete trackpad using the 4 little silver screws (not the ultra tiny black screws) and clean it thoroughly. Strongly advise to take the cable from the motherboard and guide it back through when putting it back together.
  3. Clean the space where the trackpad rests, be careful not to bend the little clips where the 4 screws came out (my mistake the first time).
  4. Last resort is to order a new trackpad for around 20 bucks used or 40 new from USA.
  5. Put in the adjustment screw before you add the trackpad as you can sort of “feel” the depth of it with your finger.
  6. Put it back together in reversed order, keeping in mind not to bend the little clips at the back as they give the height of the trackpad in comparison to the frame. Make sure ALL parts you cleaned with alcohol are completely dry (give it an hour if you must to evaporate).
  7. After everything is secured put your laptop on it’s side and gently feel if the pressure to make the click is working and if you feel/hear the click when pressing in the middle. Remember that the trackpad simulates the click once the computer has power.
I have repaired around 30 MacBook Pro units with various issues and one of them was always the trackpad as it is one of the places fluids get into quite easily.
这个答案有帮助吗?
得分 1
1条评论:
My screw is also stripped. How do I remove it?
完成的
添加一条评论
添加你的答案
Julien JACQUEMMOZ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 43
总计 2,427
